KB Shortcuts Not Working
RobertK
Version 8.0.4.1514 (new install)
This is odd, the normal Ctrl+c, Ctrl+v, Ctrl+a is not working (does not do anything)
Is this a known "issue" ?
PS: also, isn't "Execute" supposed to be mapped to F8 by default ?
Can you go to Tools > Preferences > Key Configuration and check if these functions have a key assignment?
Marco,
I was not aware, until just now, there was a "Key" column as I didn't maximize the Preference box. (so I had no idea what values were there)
I just now did "Reset to Default" and I see the Key combo values.
The fact was key combos didn't work - I *think* it was due to my migrating my previous settings.
In which file is the key combos preference stored ?
The keys are stored under the [KeyConfiguration] section in the default.ini file in your preferences directory.
