Issue with schema_name.object_name in method header when reading from db
koja
we use the following valid header for our methods in order to keep readable version and author information even when objects are wrapped.
PL/SQL Developer does have issues with this, when reading methods from the database:
1) the schema_name including the dot appear on the create or replace line and the package_name in its original position including spaces in front of it.
2) the interface notices 2 blocks, but is no longer capable of identifying them as spec and body.
create or replace package
-- $Type : PKS $
-- $Name : schema_name.package_name (header) $
-- $Abstract : blabla $
-- $Creator : Creator_name $
-- $Revision : 1.0 $
-- $Author : author $
-- $Modtime : 06-12-2019 $
schema_name.package_name is
When saving the source to file the format remains this way:
create or replace package xxyss_forwarding.
-- $Type : PKS $
pkg_csvutil is
