I am configuring PLSD 13.0.6.1911 and have encountered a difference from the behavior of the Connection Indicator preference from PLSD 12.0.7.1837.
For the connection indicators in version 12, I have the match values setup in three forms and the Set Application Background Color check box is turned on:
1. *@dbname
2. username@dbname
3. user1[user2]@dbname
In version 12, for all three cases the application background properly changes with each qualifying connection.
In version 13, I have all three types setup and the Set Application Background Color check box turned on. But only the first two forms work correctly. The third form with the proxy is not overriding the default background color, but a proxy logon to a database using the first form does work.
Thanks.
1. *@dbname
2. username@dbname
Thanks.
