Is there a way to use pl sql dev to compare data in two tables
Jeff Kish
I have two tables.
They actually have pretty much the same columns.
Is there a way to use pl sql developer to compare the data in the tables by, say, keying on two columns?
No, this is currently not possible. You are not the first to ask though, so it's on the list of enhancement requests.
you can use "minus" to do this.
select cola, colb from tablea
minus
select cola, colb from tableb
to find combinations in a that do not exist in b and then the other way around as well to find combinations in b that do not exist in a.
minus
this is restricted to distinct values however.
select c1, c2, c3,
         count(src1) CNT1,
          count(src2) CNT2
     from
   ( select a.*,
          1 src1,
          to_number(null) src2
       from a
      union all
    select b.*,
         to_number(null) src1,
         2 src2
      from b
  group by c1,c2,c3
 having count(src1) <> count(src2)
clever!
