Is "Level" a Reserved Word in 10G?
Speed
The following query has worked fine up until Oracle 10g.
select level, classn_id, classn_classn_id, classn_type, code, description
from mas.classifications
where classn_classn_id is null
union
select 0,0,0,'0','0','General Explanatory Notes' from dual
When the query is executed in 10g I get the following error:
"ORA-01788: CONNECT BY clause required in this query block". Apparently this message is misleading because a developer in another forum got the exact same error message, and he also had a field called level. When he renamed this to "tree_level" the query executed without any problems.
Does anyone know if level is a reserved word in 10g?
Thanks.
Regards,
Steve
Thanks Joachim, I wonder why it's worked before then. This system has been running for years before I took over maintenance of it and it has worked fine with all previous versions of Oracle. :confused:
Regards,
Steve
