Is it possible to connect to a db without modifying tnsnames.ora neither configuration
I haven't been able to connect ot a new db because I don't have permissions to modify the tnsnames.ora file.
Could I connect with the whole information at the moment to create a new session?
Perhaps you can use the EZCONNECT naming method? It uses the following format for the database specification:
host[:port]/database
The default port number is 1521, in which case it can be omitted:
host/database
Note that EZCONNECT needs to be enabled in the SQLNET.ORA file.
See also:
http://www.orafaq.com/wiki/EZCONNECT
