Integration PVCS: Serena VM web client 8.1.2 en_US (Build 110) and PL/SQL Developer 7
Sergey
Please, let me know - Is it possible to have it integrated?
I downloaded and installed VCS plugin 1.2. Restarted "Developer" and got empty "Available Version Control System" list in the "Preference" sub-menu.
I don't have key "HKEY_LOCAL_MACHINE\Software\SourceCodeControlProvider" in my registry.
I have key "HKEY_LOCAL_MACHINE\Software\Serena VM Web Client\..."
Should I create "\SourceCodeControlProvider\" manually?
Should I try to find web version of the "SCC Interface"?
What is the best for me?
You should not create registry keys manually. If the product comes with an SCC Interface, then this will be arranged. You will need to contact the VM vendor.
Is there a detailed guide on how to connect to network PVCS?
I downloaded the PVCS plug-in, but it is not clear how to get to the PVCS files.
If anyone knows please let me know.
Marco, all is working fine!
I've just reinstalled all from the scratch.
Thank you very much for help and for the VCS plugin!!!
