ScottMattes
I PLSD 7, only certain filetypes can be opened in the editor - has this changed since then?
I am asking because I'd like to use Projects and I'd like to keep working notes in text file that isn't named with a code file extension.
I see that I can add the text file to the project, but it opens in the Windows default text editor instead on PLSD's fine editor. That is a real bummer if all you have is Notepad!
Thank you.
Thank you.
