Initilization error / SQL*Net not properly installed
Stephen
I had the 9i client on this machine and have since uninstalled it and reinstalled 10g. I am able to successfully run SQLPLUS and attach to my remote database.
Notice the Help->Support output doesn't have any information about my TNSnames.ora file... even though it exists.
When I run PL/SQL Developer I get:
Initialization error
SQL*NET not properly installed
OracleHomeKey:
OracleHomeDir:
When I rerun the client install program, I can see where SQL*Net has been installed.
Why or how do I set these values? Why is it telling me it's not properly installed when it seems to work with SQLPLUS? I'm not a power user, so be gentle :-) I'm trying to learn.
Thanks.
Stephen
Here's the post from my Help->Support screen:
--- Info ---
PL/SQL Developer
Version 7.0.3.1123 (MBCS)
01.37532 - 1 user license
Windows XP version 5.5 (build 3790) Service Pack 1
Physical memory : 2,094,460 kB (1,205,928 available)
Paging file : 4,057,372 kB (3,414,324 available)
Virtual memory : 2,097,024 kB (2,015,340 available)
Parameters
C:\Program Files\PLSQL Developer\PLSQLDev.exe
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
C:\Program Files\PLSQL Developer\Preferences\Default\Default.ini
C:\Program Files\PLSQL Developer\Preferences\susrey\default.ini
Plug-Ins
TNSEditor Plugin (C:\Program Files\PLSQL Developer\PlugIns\TNSEditorPlugin.dll)
Aliases
Homes
DLLs
TNS File
Using
Home:
DLL:
OCI: not initialized
--- Registry ---
SOFTWARE\ORACLE
--- Path ---
D:\oracle\product\10.2.0\client_1\bin
C:\Perl\bin\
C:\PROGRA~2\Borland\CBUILD~1\Bin
C:\PROGRA~2\Borland\CBUILD~1\Projects\Bpl
C:\WINDOWS\system32
C:\WINDOWS
C:\WINDOWS\System32\Wbem
C:\Program Files (x86)\Common Files\Roxio Shared\DLLShared\
--- TNS names ---
Bueller?.....Bueller?..... Bueller?
I really could use some help on this is somebody has some ideas. I need to be coding but am unable to access the database.
Stephen
The Oracle Client you are using is not registered (in the Oracle registry), and therefore PL/SQL Developer cannot find it. You can either reinstall it, or start PL/SQL Developer without connecting, go to Tools > Preferences > Oracle / Connection, enter D:\oracle\product\10.2.0\client_1\bin\oci.dll in the "OCI Library" field, and restart PL/SQL Developer.
Thanks Marco :-)
I reinstalled the 10g client and set the field above as stated, but still get:
Could not load "D:\oracle\product\10.2.0\client_1\bin\oci.dll"
OCIDLL forced to D:\oracle\product\10.2.0\client_1\bin\oci.dll
LoadLibrary(D:\oracle\product\10.2.0\client_1\bin\oci.dll) returned 0
I didn't get any errors during the 10g client install. Any other ideas?
Thanks!
