Incorrect default editor colors in light mode in Beta 3 and earlier
Administrator
Staff member
The editor keyword colors in light mode could be incorrect after using Beta 3 or earlier. The "Symbol" color was light blue (cyan), and the "Keyword" color was brownish. To fix this you can go to Preferences > User Interface > Editor and click on the green indicator of the "Syntax highlighting" color section. This will revert the editor to the correct default colors.
In dark mode the default editor colors are correct.
To fix all colors, you can do the following:
  1. Download this light.zip file.
  2. Exit PL/SQL Developer.
  3. Go to %APPDATA%\PLSQL Developer 15\Preferences\Themes
    (e.g. C:\Users\\AppData\Roaming\PLSQL Developer 15\Preferences\Themes)
  4. Unzip the downloaded light.ini file to replace the existing file.
  5. Restart PL/SQL Developer.
