Impossible to retrieve view code
Oxiane
I've got a strange problem. Whene I try to edit or just view some views (not the result, the code !), the program hangs, and I've to kill him after
mytables means a lot of tables or just one?
If there is a lot of tables, then of course there will be perf. loss, and that's then not developer...
No, I don't *query* the datas, I'm just trying to get the sql code of the view :
- My view is already created and is properly working
- In the "Object" list, I click right, and then choose 'View' or 'Edit'
--> No response, and I have to kill PLS Developer.
In DBA studio, no problem to get the sql code of the view, that's why I think the problem comes from PL/SQL Developer.
I've got the same problem when I try to get the excution plan for a query to my view (no, I don't *execute* the query ;-) )
Thanks for your help.
I've installed the new release (6.0.6.946), and I still have have the same problem.
Is it supposed to be fixed with this release ?
No, with the upcoming 7.0 release. We only released 6.0.6 for 10g Release 2 compatibility. It was not originally planned.
We specifically upgraded to Version 7.0.3.1123 to overcome this problem but we are still finding it happens. We work with a lot of views so find this particularly frustrating. Is it possible to revisit this bug?
For me, the problem is fixed (version 7.0.3.1123).
No more problems with my views :-)
Thanks a lot, I really like your product.
