I encountered the same problem on my production database. Here's an excerpt from debug.txt (cannot send full file, as it contains confidential info, so i included only parts of it that have oracle errors):
00:00:07.023 TOracleQuery $06029B90 Start Query.Execute
sys.plsqldev_authorization
00:00:07.234 TOracleQuery $06029B90 End
Duration = 0,172
00:03:11.431 TOracleQuery ImportForm.Query Start Query.Execute
SQL = insert into APP_OBJECTS
(app_project, app_obj_type, app_obj_name, app_obj_caption, app_obj_description, app_obj_source_1, app_obj_source_2, app_obj_first_in, app_obj_first_out, creation_date, creation_user, modification_date, modification_user)
values
v0, :v1, :v2, :v3, :v4, empty_clob(), null, :v7, :v8, :v9, :v10, :v11, :v12)
returning app_obj_source_1, app_obj_source_2 into :v5, :v6
:V0 = mmm
:V1 = kkk
:V2 = zzz
:V3 = yyy
:V4 = yyy
:V5S = empty_clob()
:V5 = (CLOB)
:V6S = null
:V6 = (CLOB)
:V7 = Null
:V8 = Null
:V9 = 02-02-2100 10:00:00
:V10 = XXX
:V11 = 02-02-2100 10:00:00
:V12 = XXX
00:03:11.521 TOracleQuery ImportForm.Query End (1 record processed)
Duration = 0.078
00:03:11.546 TLOBLocator Start LOB.Write(6276)
00:03:11.653 TLOBLocator End
Result = Access violation at address 5B24B2CC in module 'OraClient12.Dll'. Write of address 00000000
Duration = 0.094
00:03:11.663 TOracleQuery ImportForm.Query Start Query.Execute
SQL =
00:03:11.776 TOracleQuery ImportForm.Query End
Result = ORA-01013: user requested cancel of current operation
Duration = 0.109
00:03:11.796 TOracleQuery ImportForm.Query Start Query.Execute
SQL =
00:03:11.891 TOracleQuery ImportForm.Query End
Result = ORA-24909: call in progress. Current operation cancelled
Duration = 0.078
00:03:11.911 TOracleQuery ImportForm.Query Start Query.Execute
SQL =
00:03:11.933 TOracleQuery ImportForm.Query End
Result = ORA-03114: not connected to ORACLE
Duration = 0
All next queries end with this error. It seems like the error is related to LOB processing.
I'm running Oracle 12.1.0.2 database. Connection is established through Oracle 12c client.
PL/SQL Developer 11.0.6.1776.
