Icons not visible after Logon with Remote Desktop
stef
When I have HomeOffice ( sometimes this happens) I will connect to my WS with RemoteDesktop ( Win 7). After that when I'm back in the office and connect to my system all ICONS in PL/SQL dev 9.0.1601 are ..how can I say...no color at all.
This is only happening in PLSQL, all other programms are ok
Please help, I alway's have to restart the developer.
thx
br
Stef
Can you send me a screenshot of this issue? Does it only apply to toolbar buttons or also to buttons and images elsewhere in PL/SQL Developer?
Ok I will arrange this.
What I could investigate also is, that this only happen if I'm not locked in when I connect to the session.
So before I connect with RDP, I disconnect my sessions.
Br
This happens to me also. The icons retain their shape but are light gray color. Same scenario. Been working via Remote Desktop then come into the office and the icons are messed up. Restarting PL/SQL D is the only way to get them back. A fix would be nice. I'm on a Windows 7 64-bit workstation.
Does it help if you change any of the options on the "Experience" tab page of the Remote Desktop Connection?
And I have this same issue too. I use full screen, no color reduction etc. Have the issue on the floating bars and windows as well. The weird thing is it's not all buttons but only a couple of them. The import and export buttons on the define connection for instance. And the find, filters and folders button on the object browser.
Kind regards,
Jan
