I have the latest version installed v13.0.3.1902 x64, running on Windows 7 Ultimate. I just noticed that the tooltip functionality (that shows, for instance, a variable definition in a tooltip when you hover over the variable name in code within a PL/SQL window) does not work in a SQL Window. Also, the hyperlink navigation that works in a PL/SQL Window (when you hold down the Ctrl key and then left or right click on the variable name or procedure name etc.), also does not work in a SQL Window. Is this by design? If so, can an option be added to turn this functionality on for SQL Windows (assuming there isn't one already)?
