HOWTO: Manually deinstall PL/SQL Developer?
StefanM
Over the weekend I installed version 10 of PL/SQL-Devloper in a new directory. Then I wanted to deinstall the previous version 9 noticing that there are a number of entries in the list of installed programs named "PL/SQL Devloper" and "PL/SQL Devloper [2]" and the like. The deinstall was a bit too fast and none of the files nor the icon was removed. So now I end up with 3 PLSQLDeveloper directories in C:\Programs(x86) and only one entry for version 10 in the install list.
How can I manually remove version 9? There is a uninstall.ini and AdminSetup.exe in the V9 directory.
Stefan
