How to write file to blob field using fixed transfer buffer.
Klestov
How to write file to blob field using fixed transfer buffer?
My Source code (DOA Version 3.4.6.4):
TOracleDataSet * m_OracleDataSet;
........... // LogOn and e.t.c.
m_OracleDataSet->ReadOnly = false;
m_OracleDataSet->ReadBuffer = 1;
I want write content file 'my_file_name' to blob field 'my_blob' of first row from result set.
m_OracleDataSet->SQL->Text = "select rowid , my_blob from my_table";
m_OracleDataSet->Open();
if (m_OracleDataSet->FieldCount == 1)
m_OracleDataSet->First();
if ((m_OracleDataSet->Eof == false) && (m_OracleDataSet->Bof == true))
if (m_OracleDataSet->Fields->Fields[0]->IsBlob() == true)
if ((m_OracleDataSet->CanModify == true) && (m_OracleDataSet->ReadOnly == false))
TBlobField * BlobField = dynamic_cast(m_OracleDataSet->Fields->Fields[0]);
if (BlobField != NULL)
// Size file 'my_file_name' is N bytes.
// WARNING !! : This operation allocate memory > 2N.
// if N = 50Mb - allocate > 100Mb !!!!!!
m_OracleDataSet->Edit(); // Start edit.
BlobField->LoadFromFile("my_file_name");
m_OracleDataSet->Post(); // Post data to DB.
// How to write file 'my_file_name' to blob field using fixed transfer buffer size of M.
// M ~ 10Kb.
// Memory in client PC is small ~ 64Mb. Using swap file is very very slow.
m_OracleDataSet->CloseAll();
Use a TOracleQuery and a TLOBLocator instead. This allow you to control exactly how the data is read and written, and is most suitable when resources are limited.
No, in that case you need to use the TOracleQuery->SetLongVariable and GetLongField functions.
