How to send mail using PLSQL
I tried sending mail using the inbuilt packages available in PLSQL like UTL_SMTP and UTL_mail. But using both the packages I m not able to send any mail, Can anyone please explain how to send mail from PLSQL directly??
Thanks in advance...
This works form me. Simple for text e-mails:
CREATE OR REPLACE Procedure Send_mail(in_receiver Varchar2, in_subject In Varchar2, in_text In Varchar2) Is
-- Author : DoDo
c utl_smtp.connection;
Procedure Send_Header(Name In Varchar2, Header In Varchar2) As
Begin
Utl_Smtp.Write_Data(c, Name || ': ' || Header || Utl_Tcp.Crlf);
End;
Begin
Utl_Tcp.CRLF := chr(13)||Chr(10);
c := Utl_Smtp.Open_Connection('000.000.000.000'); -- IP ADDRESS OF MAIL SERVER
Utl_Smtp.Helo(c, 'acme.com');
Utl_Smtp.Mail(c, 'acme@acme.com'); -- From
Utl_Smtp.Rcpt(c, in_receiver);
Utl_Smtp.Open_Data(c);
Send_Header('From', '"OracleServer" ');
Send_Header('To', '');
Send_Header('Subject', in_subject);
Utl_Smtp.Write_Data(c, Utl_Tcp.Crlf || in_text);
Utl_Smtp.Close_Data(c);
Utl_Smtp.Quit(c);
Exception When Utl_Smtp.Transient_Error Or Utl_Smtp.Permanent_Error
Then Utl_Smtp.Quit(c); Raise_Application_Error(-20000, 'Failed to send mail due to the following error: ' || Sqlerrm);
End;
I have given the system's IP as the SMTP server address, and I dont know how to find the SMTP server name and port, using show parameters I gave the system ip as smtp server ip and the port as 1521 which is used by my oracle database to the smtp_out_server. Can you please help me how to resolve my problem.....and thanks a lot for the response :) :) :)
