How to return(send) message PlugIns ?
HOME_X
Hello !!!!
I have the DLL code for PlugIns.
I want at execute function to return the system message
SQL_Execute: function(SQL: PChar): Integer; cdecl;
Example
Initializing
Executing
1000 rows selected in 1.45 seconds (more…)
Executing ….. (2000)
5000 rows selected in 13.65 seconds
And command to halt query (analogue of the keys Shift+Esc)
Thank You !
Good Day Marco Kalter !
Now ? Example ?
I Dispose function
SQL_FieldCount: function: Integer; cdecl;
SQL_Eof: function: Bool; cdecl;
SQL_Next: function: Integer; cdecl;
SQL_Field: function(Field: Integer): PChar; cdecl;
SQL_FieldName: function(Field: Integer): PChar; cdecl;
SQL_FieldIndex: function(Name: PChar): Integer; cdecl;
SQL_FieldType: function(Field: Integer): Integer; cdecl;
Thank You !
Forgive errors during translation ..
Your answer - "You can only show messages in your own forms/dialogs."
System message application or user message ?????
Example user message(Delphi)
ShowMessage('Begin SQL');
SQL_Execute(PChar(Memo.Text));
ShowMessage('End SQL');
Example system message(Delphi)
SQL_Execute(PChar(Memo.Text)) - start by a separate stream
Now return system message (function/variables)?
Initializing, Executing........
Thank You !
