hello:
i have a question about PL/SQL Developer Version 7.1.1.1341
i what to format my plsql FUNCTION like this :
keywords are uppercase.
identifiers are lowercase except the name of function.
then how to edit the *.br file to achieve my aim?
for example :
before beautifier :
FUNCTION mgrname(p_empno IN emp.empno%TYPE) RETURN emp.ename%TYPE IS
RESULT emp.ename%TYPE;
i INTEGER;
RESULT := NULL;
i := 1;
IF p_empno IS NULL THEN
-- If empno is null, return an empty name
RESULT := NULL;
ELSE
-- Fetch the name of the manager
SELECT m.ename
INTO RESULT
FROM emp e, emp m
WHERE e.empno = p_empno
AND m.empno = e.mgr
AND d.deptno IN (10, 20, 30, 40);
END IF;
RETURN(RESULT);
EXCEPTION
WHEN no_data_found THEN
RETURN(NULL);
END;
after beautifier:
FUNCTION MGRNAME(p_empno IN emp.empno%TYPE) RETURN emp.ename%TYPE IS
i INTEGER;
RESULT := NULL;
i := 1;
RESULT := NULL;
ELSE
SELECT m.ename
INTO RESULT
FROM emp e, emp m
AND m.empno = e.mgr
END IF;
RETURN(RESULT);
EXCEPTION
RETURN(NULL);
END;
thank you very much.
for example :
before beautifier :
i INTEGER;
RESULT := NULL;
i := 1;
RESULT := NULL;
ELSE
SELECT m.ename
INTO RESULT
FROM emp e, emp m
AND m.empno = e.mgr
END IF;
RETURN(RESULT);
EXCEPTION
RETURN(NULL);
END;
after beautifier:
i INTEGER;
RESULT := NULL;
i := 1;
RESULT := NULL;
ELSE
SELECT m.ename
INTO RESULT
FROM emp e, emp m
AND m.empno = e.mgr
END IF;
RETURN(RESULT);
EXCEPTION
RETURN(NULL);
END;
