Hi, I am struggling to find the place where to configure a SSL connection using a trust store.
My TNS Names entry:
ORAPRODSSL =
(DESCRIPTION=
(ADDRESS_LIST=
(ADDRESS=(PROTOCOL=TCPS)(HOST=host123.rds.amazonaws.com)(PORT = 2484))
(CONNECT_DATA =
(SERVER = DEDICATED)
(SERVICE_NAME = orcl)
My SQL Ora Net entry:
SQLNET.AUTHENTICATION_SERVICES= (TCPS,NTS)
WALLET_LOCATION = (SOURCE = (METHOD = FILE) (METHOD_DATA = (DIRECTORY = "C:\tools\instantclient_19_6\oracle_ssl_wallet")))
SSL_CLIENT_AUTHENTICATION = FALSE
SQLNET.ENCRYPTION_CLIENT=ACCEPTED
SSL_VERSION = 1.2
SSL_CIPHER_SUITES = (SSL_RSA_WITH_AES_256_CBC_SHA, SSL_RSA_WITH_AES_256_CBC_SHA, SSL_RSA_WITH_AES_256_GCM_SHA384)
In Oracle's SQL Developer tool it is possible to enter advanced properties/values for the TNS name:
javax.net.ssl.trustStore
javax.net.ssl.trustStorePassword
If I go on without these properties I get the ORA-28860
I am sure it must be somehow possible, maybe in my java environment?
Any help is very much appreciated.
Donald
PS: I am using PL/SQL Developer 13.0.6.1911 (64 bit)
			My TNS Names entry:
ORAPRODSSL =
(DESCRIPTION=
(ADDRESS_LIST=
(CONNECT_DATA =
SSL_VERSION = 1.2
Donald
