How to assign a Cursor to another Cursor?
Roeland
I have declared a cursor in one package and i want to assign it in another package:
Example:
Package Test1 ...
cursor c1 is
select 'a', 'b' from dual;
end Test1;
Package Test2...
cursor c2 = Test1.c1; -- Something like this??
-- or
type c2 is cursor Test1.c1; -- Something like this??
end Test2;
I hope it's clear what i want to achieve. (to make a new cursor type that references another cursor type).
Does anyone know how to do this?
Not sure if this helps, but you can use cursor declared in another package without assigning it to a variable.
create or replace package pkg_rc is
    -- Public cursor declarations
    cursor test_c is select count(*) cnt from dual;
end pkg_rc;
create or replace package pkg_test_rc is
    -- Public function and procedure declarations
    procedure test;
end pkg_test_rc;
create or replace package body pkg_test_rc is
  -- Function and procedure implementations
  procedure test
  is
      l_rec pkg_rc.test_c%rowtype;
      open pkg_rc.test_c;
      fetch pkg_rc.test_c into l_rec;
      dbms_output.put_line(l_rec.cnt);
      close pkg_rc.test_c;
end pkg_test_rc;
set serveroutput on
exec pkg_test_rc.test
You can only assign cursor variables if they are of the same cursor type. For example:
declare
  type EmpCurTyp is ref cursor return emp%rowtype;
  EmpCur1 EmpCurTyp;
  EmpCur2 EmpCurTyp;
  EmpRec emp%rowtype;
  open EmpCur1 for select * from emp;
  EmpCur2 := EmpCur1;
  fetch EmpCur2 into EmpRec;
  dbms_output.put_line(EmpRec.ename);
  close EmpCur1;
Thanks for the help, but it's not what i want.
The problem is that I have a package that's different for some customers due to historically and practical reasons. (The most of the methods is the same, but not all). Now i want to "interface" that old package with a standard package and subtype everything in this new package.
I can delegate functions, procedures and types, but it seems i can't do this for cursors.
I don't want to access the old package directly, because that would make my other packages also customer specific...
So it's not about cursor variables, it's about the cursors themselves.
Roeland
