How to access a long raw column?
DanCT
I'm using Delphi 5, with DOA 3.4.6 to connect to an Oracle 9i database. I have a long raw column that I'm trying to access, with the eventual goal of storing each line (it's mostly text) in a TMemo.
I cannot get this to work. So far, I'm using:
TheBlob := TLOBLocator.Create(Oracle,otBlob);
    with SQLQuery do
        Session := Oracle;
        SQL.Clear;
        SQL.Add('SELECT longrawcol FROM mytable WHERE id = 1');
        Execute;
    TheBlob := SQLQuery.LOBField(0);
The error that I get is "Field LONGRAWCOL is not a LOB".
Any ideas?
From the User's Guide:
Long Raws are handled as zero based variant arrays of bytes. To access the byte-array with the highest possible performance, make use of the VarArrayLock and VarArrayUnlock functions. To check for the size of the value, make use of VarArrayHighBound. The next example fetches a picture, determines the size, and saves the binary data to disk:
// SelectEmpPictureQuery.SQL =
// select picture from emp
// where empno = :empno
try
  with SelectEmpPictureQuery do
    SetVariable('EMPNO', Emp.EmpNo);
    Execute;
    Picture := Field('PICTURE');
    Size    := VarArrayHighBound(Picture, 1) + 1;
    Ptr     := VarArrayLock(Picture);
    WriteFile('Employee.gif', Ptr^, Size);
    VarArrayUnlock(Picture);
except
  on E:EOracleError do ShowMessage(E.Message);
There is a demo named LongRaw in the Demos directory of DOA.
