Hot key for columns
Dean Lamper
Is there a quick key, that would insert all columns of the 'current' table, i.e. a table that is written on the left side of the cursor?.
For example, when writing insert clause, I would write INSERT INTO sch.SOME_TABLE and then press a hot key and (COL_1, COL_2, COL_3) would appear aside the table name. It would quite ease up writing querries.
There is no key or function for this. The Code Assistant will show you the column names after typing a comma though. Furthermore you can drag & drop a table from the Object Browser into an Editor and select "Insert" from the popup menu to create a complete insert statement.
