help!!
shadow
Editing data with PL/SQL Developer5.1 just need 1or 2 seconds delay after clicking data cell. But in later version, there is more than 30 seconds delay and I can't figure out the reason.
PL/SQL Developer 7.0.1.1066 18253.6320 - Unlimited user license
D:\tools\PLSQL Developer\plsqldev.exe
2006-3-25 16:59:48 Application started
2006-3-25 16:59:48 InitPreferences
2006-3-25 16:59:48 Load D:\tools\PLSQL Developer\Preferences\Default = 0
2006-3-25 16:59:48 PreferenceSet.Load D:\tools\PLSQL Developer\Preferences\Default\Default.ini
2006-3-25 16:59:48 PreferenceSet.Load OK
2006-3-25 16:59:48 PreferenceSet.Save
2006-3-25 16:59:48 PreferenceSet filename = D:\tools\PLSQL Developer\Preferences\Default\Default.ini
2006-3-25 16:59:48 PreferenceSet.Save end
2006-3-25 16:59:48 Load D:\tools\PLSQL Developer\Preferences\Administrator = 0
2006-3-25 16:59:48 PreferenceSet.Load D:\tools\PLSQL Developer\Preferences\Administrator\default.ini
2006-3-25 16:59:48 PreferenceSet filename = D:\tools\PLSQL Developer\Preferences\Administrator\default.ini
2006-3-25 16:59:48 PreferenceSet.Load D:\tools\PLSQL Developer\Preferences\Administrator\user.prefs
2006-3-25 16:59:48 InitPreferences end
2006-3-25 16:59:48 SortPreferenceSets
2006-3-25 16:59:48 - Default Administrator
2006-3-25 16:59:48 - System Default
2006-3-25 16:59:49 LoadPreferences
2006-3-25 16:59:49 LoadPreferences searching for default
2006-3-25 16:59:49 D:\tools\PLSQL Developer\Preferences\Administrator\default.ini
2006-3-25 16:59:49 LoadPreferences end
2006-3-25 16:59:49 FormCreate Logon.Execute
2006-3-25 16:59:53 TOracleSession PLSQLDevForm.Session Start Session.LogOn as report@ods
2006-3-25 16:59:53 TOracleQuery Query Start Query.Execute
2006-3-25 16:59:53 TOracleQuery Query End (1 record processed)
Duration = 0.01
2006-3-25 16:59:53 TOracleSession PLSQLDevForm.Session End
Duration = 0.241
2006-3-25 16:59:53 LogonHistorySave start
2006-3-25 16:59:53 ChangeUserPref LogonHistory,
2006-3-25 16:59:53 ChangeUserPref DSA,
2006-3-25 16:59:53 ChangeUserPref end
2006-3-25 16:59:53 ChangeUserPref ColumnAssociations,
2006-3-25 16:59:53 ChangeUserPref ImportAssociations,
2006-3-25 16:59:53 ChangeUserPref BrowserFilters,
2006-3-25 16:59:53 ChangeUserPref BrowserFolders,
2006-3-25 16:59:53 ChangeUserPref SessionQueries,
2006-3-25 16:59:53 ChangeUserPref ExternalTools,
2006-3-25 16:59:53 ChangeUserPref Documents,
2006-3-25 16:59:53 ChangeUserPref Reports,
2006-3-25 16:59:53 LogonHistorySave end
2006-3-25 16:59:53 FormCreate Session.Connected
2006-3-25 16:59:53 FormCreate Logon.Executed -1
2006-3-25 16:59:53 FormCreate TDBNames.Make
2006-3-25 16:59:53 FormCreate SessionChanged
SQL = select * from v$version
2006-3-25 16:59:53 TOracleQuery Query End (5 records processed)
Duration = 0
2006-3-25 16:59:53 SessionChanged SetDBAViews
2006-3-25 16:59:53 SessionChanged Authorizations.Load
2006-3-25 16:59:53 TOracleQuery $017E6E50 Start Query.Execute
sys.plsqldev_authorization
2006-3-25 16:59:53 TOracleQuery $017E6E50 End
Result = ORA-00942: 表或视图不存在
Duration = 0.01
2006-3-25 16:59:53 SessionChanged EnableAuthorizedMenus
2006-3-25 16:59:53 TOracleSession $021BD6F0 Start Session.LogOn as report@ods
2006-3-25 16:59:54 TOracleQuery Query Start Query.Execute
2006-3-25 16:59:54 TOracleQuery Query End (1 record processed)
Duration = 0.01
2006-3-25 16:59:54 TOracleSession $021BD6F0 End
Duration = 0.791
2006-3-25 16:59:54 SetSessionAction starts: Main session
2006-3-25 16:59:54 TOracleQuery $017E6F90 Start Query.Execute
SQL = select null from dual
2006-3-25 16:59:54 TOracleQuery $017E6D10 Start Query.Execute
from sys.user_objects o
2006-3-25 16:59:54 TOracleQuery $017E6F90 End (1 record processed)
Duration = 0.01
:ACTION = Main session
2006-3-25 16:59:54 TOracleQuery BytesPerCharacterQuery Start Query.Execute
SQL = select length(chr(2000000000)) l4, length(chr(2000000)) l3, length(chr(20000)) l2 from dual
2006-3-25 16:59:54 TOracleQuery $017E6D10 End (100 records processed)
Duration = 0.01
2006-3-25 16:59:54 TOracleQuery $017E6D10 Start Query.Next for up to 100 records
2006-3-25 16:59:54 TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0.01
Duration = 0.02
2006-3-25 16:59:54 SetSessionAction ends
2006-3-25 16:59:54 ExecuteConnectScript starts
2006-3-25 16:59:54 ExecuteConnectScript ends
2006-3-25 16:59:54 TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Execute
Duration = 0.03
2006-3-25 16:59:54 TOracleQuery PLSQLDevForm.DynamicQuery End (1 record processed)
Duration = 0.04
2006-3-25 16:59:54 SessionChanged LoadRecentObjects
2006-3-25 16:59:54 SessionChanged Notify children
2006-3-25 16:59:54 SessionChanged Logoff secondary sessions
2006-3-25 16:59:54 SessionChanged SessionMode = smMulti
2006-3-25 16:59:54 SessionChanged EnableChildFunctions
Duration = 0.06
Duration = 0.01
Duration = 0.05
Duration = 0.01
OracleHomeKey: SOFTWARE\ORACLE\HOME0
OracleHomeDir: D:\oracle\ora90
Found: oci.dll
Using: D:\oracle\ora90\bin\oci.dll
Duration = 0.11
Duration = 0.02
2006-3-25 16:59:54 TOracleQuery $017E6D10 End (71 records processed)
Duration = 0.01
from sys.all_synonyms s,
sys.all_objects o
and o.owner = s.table_owner
2006-3-25 16:59:55 TOracleQuery $017E6D10 End (100 records processed)
Duration = 0.341
2006-3-25 16:59:55 TOracleQuery $017E6D10 Start Query.Next for up to 100 records
Duration = 0.01
Duration = 0.01
Duration = 0.02
Duration = 0.02
Duration = 0.02
Duration = 0.03
Duration = 0.01
Duration = 0.01
Duration = 0.01
Duration = 0.02
Duration = 0.01
Duration = 0.02
Duration = 0.07
Duration = 0.01
Duration = 0.05
Duration = 0.04
2006-3-25 16:59:55 TOracleQuery $017E6D10 End (48 records processed)
Duration = 0.161
2006-3-25 16:59:55 TOracleSession $021BD6F0 Start Session.LogOff
2006-3-25 16:59:55 TOracleSession $021BD6F0 End
Duration = 0
2006-3-25 16:59:56 SortPreferenceSets
2006-3-25 16:59:56 - Default Administrator
2006-3-25 16:59:56 - System Default
2006-3-25 16:59:59 Create TSQLForm
2006-3-25 16:59:59 SQLForm
2006-3-25 17:00:08 SQLForm Initializing...
2006-3-25 17:00:08 SetConnected starts
2006-3-25 17:00:08 SetConnected: Connect starts
2006-3-25 17:00:08 TOracleSession $021BE410 Start Session.LogOn as report@ods
2006-3-25 17:00:08 TOracleQuery Query Start Query.Execute
2006-3-25 17:00:08 TOracleQuery Query End (1 record processed)
Duration = 0
2006-3-25 17:00:08 TOracleSession $021BE410 End
Duration = 0.17
2006-3-25 17:00:08 SetConnected: (Dis)connect ends
2006-3-25 17:00:08 SetSessionAction starts: SQL Window - New
2006-3-25 17:00:08 TOracleQuery $017E7490 Start Query.Execute
2006-3-25 17:00:08 TOracleQuery $017E7490 End (1 record processed)
Duration = 0
:ACTION = SQL Window - New
2006-3-25 17:00:08 TOracleQuery BytesPerCharacterQuery Start Query.Execute
2006-3-25 17:00:08 TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0.01
Duration = 0.02
2006-3-25 17:00:08 SetSessionAction ends
2006-3-25 17:00:08 ExecuteConnectScript starts
2006-3-25 17:00:08 ExecuteConnectScript ends
Duration = 0.01
2006-3-25 17:00:08 EnableOutput starts
2006-3-25 17:00:08 TOracleQuery PLSQLDevForm.EnableOutputQuery Start Query.Execute
SQL = begin
if :enable = 0 then
sys.dbms_output.disable;
else
sys.dbms_output.enable(:size);
end if;
:ENABLE = 1
:SIZE = 10000
2006-3-25 17:00:08 TOracleQuery PLSQLDevForm.EnableOutputQuery End
Duration = 0
2006-3-25 17:00:08 EnableOutput done
2006-3-25 17:00:08 InitStatistics starts
2006-3-25 17:00:08 TStatistics.Init starts
2006-3-25 17:00:08 TStatistics.Init ends
2006-3-25 17:00:08 InitStatistics ends
2006-3-25 17:00:08 SQLForm Executing...
2006-3-25 17:00:08 TSQLThread SQLThread.Execute
:ID = Null
Duration = 0
2006-3-25 17:00:08 TOracleQuery $017E7710 Start Query.Execute
SQL = select t.*,t.rowid from mid_sms_sum_mon_g_t t
2006-3-25 17:00:08 TOracleQuery $017E7710 End (100 records processed)
Duration = 0.03
2006-3-25 17:00:08 TOracleQuery SQLForm.TestQuery Start Query.Describe
SQL = SELECT * FROM mid_sms_sum_mon_g_t
2006-3-25 17:00:08 TOracleQuery SQLForm.TestQuery End
Duration = 0.01
2006-3-25 17:00:08 SQLForm Executing... (10)
2006-3-25 17:00:08 SQLForm Executing... (20)
2006-3-25 17:00:08 SQLForm Executing... (30)
:ID = Null
Duration = 0.01
2006-3-25 17:00:08 TSQLThread SQLThread Postmessage
2006-3-25 17:00:08 TSQLThread SQLThread Suspend
2006-3-25 17:00:08 TSQLForm.ThreadFinished
2006-3-25 17:00:08 TSQLForm.ThreadFinished: SQLThread.Suspended
2006-3-25 17:00:08 SQLForm 32 rows selected in 0.331 seconds (more...)
2006-3-25 17:00:08 TOracleQuery $017E75D0 Start Query.Execute
SQL = begin
:LINE = Null
:STATUS = Null
2006-3-25 17:00:08 TOracleQuery $017E75D0 End
Duration = 0
2006-3-25 17:00:15 TOracleQuery PLSQLDevForm.ResolveSymbolQuery Start Query.Execute
SQL = declare
t_owner varchar2(30);
t_name varchar2(30);
procedure check_mview is
dummy integer;
if :object_type = 'TABLE' then
select 1 into dummy
from sys.all_objects
where owner = :object_owner
and object_name = :object_name
and object_type = 'MATERIALIZED VIEW'
and rownum = 1;
:object_type := 'MATERIALIZED VIEW';
end if;
exception
when others then null;
:sub_object := null;
if :deep != 0 then
if :part2 is null then
from sys.all_constraints c
where c.constraint_name = :part1 and c.owner = user
and rownum = 1;
else
select constraint_type, owner, constraint_name, :part3
where c.constraint_name = :part2 and c.owner = :part1
and rownum = 1;
end if;
if :object_type = 'P' then :object_type := 'PRIMARY KEY'; end if;
if :object_type = 'U' then :object_type := 'UNIQUE KEY'; end if;
if :object_type = 'R' then :object_type := 'FOREIGN KEY'; end if;
if :object_type = 'C' then :object_type := 'CHECK CONSTRAINT'; end if;
return;
exception
when no_data_found then null;
end if;
:sub_object := :part2;
if (:part2 is null) or (:part1 != user) then
select object_type, user, :part1
where owner = user
and object_name = :part1
and object_type in ('MATERIALIZED VIEW', 'TABLE', 'VIEW', 'SEQUENCE', 'PROCEDURE', 'FUNCTION', 'PACKAGE', 'TYPE', 'TRIGGER', 'SYNONYM')
and rownum = 1;
if :object_type = 'SYNONYM' then
select s.table_owner, s.table_name
into t_owner, t_name
where s.synonym_name = :part1
and s.owner = user
and rownum = 1;
select o.object_type, o.owner, o.object_name
from sys.all_objects o
where o.owner = t_owner
and o.object_name = t_name
and rownum = 1;
end if;
if :part3 is not null then
:sub_object := :sub_object || '.' || :part3;
end if;
check_mview;
return;
exception
end if;
and s.owner = 'PUBLIC'
and rownum = 1;
and rownum = 1;
check_mview;
return;
exception
:sub_object := :part3;
where o.owner = :part1
and o.object_name = :part2
and rownum = 1;
check_mview;
return;
exception
if :part2 is null and :part3 is null
then
select 'USER', null, :part1
from sys.all_users u
where u.username = :part1
and rownum = 1;
return;
end if;
exception
if :part2 is null and :part3 is null and :deep != 0
then
select 'ROLE', null, :part1
from sys.session_roles r
where r.role = :part1
and rownum = 1;
return;
end if;
exception
:object_owner := null;
:object_type := null;
:object_name := null;
:PART1 = MID_SMS_SUM_MON_G_T
:OBJECT_TYPE = Null
:OBJECT_OWNER = Null
:OBJECT_NAME = Null
:PART2 =
:SUB_OBJECT = Null
:PART3 =
:DEEP = 0
2006-3-25 17:00:15 TOracleQuery PLSQLDevForm.ResolveSymbolQuery End
Duration = 0.02
2006-3-25 17:00:15 TOracleQuery PLSQLDevForm.ColumnQuery Start Query.Execute
SQL = select col.*, com.Comments
from sys.all_tab_columns col,
sys.all_col_comments com
where col.owner = :owner
and col.table_name = :table_name
and com.Owner (+) = :Owner
and com.Table_Name (+) = :table_name
and com.Column_Name (+) = col.Column_Name
order by col.column_id
:TABLE_NAME = MID_SMS_SUM_MON_G_T
:OWNER = REPORT
2006-3-25 17:00:15 TOracleQuery PLSQLDevForm.ColumnQuery End (1 record processed)
Duration = 0.02
2006-3-25 17:00:15 TOracleQuery PLSQLDevForm.ColumnQuery Start Query.Next for up to 1 record
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0.01
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
2006-3-25 17:00:15 TOracleQuery PLSQLDevForm.ColumnQuery End (0 records processed)
Duration = 0.01
2006-3-25 17:00:15 TOracleQuery $017E75D0 Start Query.Execute
SQL = select tablespace_name, to_char(pct_free) pct_free, to_char(pct_used) pct_used,
to_char(ini_trans) ini_trans, to_char(max_trans) max_trans,
to_char(initial_extent) initial_extent, to_char(next_extent) next_extent,
to_char(pct_increase) pct_increase,
to_char(min_extents) min_extents, to_char(max_extents) max_extents,
cluster_name
from sys.all_tables
and table_name = :object_name
:OBJECT_OWNER = REPORT
:OBJECT_NAME = MID_SMS_SUM_MON_G_T
2006-3-25 17:00:15 TOracleQuery $017E75D0 End (1 record processed)
Duration = 0.01
SQL = select *
from sys.all_tables
Duration = 0.01
SQL = select comments from sys.all_tab_comments
Duration = 0
:OWNER = REPORT
Duration = 0.01
2006-3-25 17:00:15 TOracleQuery $017E75D0 Start Query.Next for up to 1 record
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.02
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.011
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
2006-3-25 17:00:15 TOracleQuery $017E75D0 End (0 records processed)
Duration = 0
SQL = select * from sys.all_constraints
where table_name = :object_name
and owner = :object_owner
and constraint_type in ('P', 'U', 'R', 'C')
order by decode(constraint_type, 'P', 0, 'U', 1, 'R', 2, 3), constraint_name
Duration = 0.01
SQL = select * from sys.all_indexes
and table_owner = :object_owner
order by index_name
Duration = 0.02
SQL = select * from sys.all_tab_privs
where table_schema = :object_owner
order by grantee
Duration = 0.01
SQL = select * from sys.all_tab_partitions
and trim(composite) = 'NO'
order by partition_position
2006-3-25 17:00:17 TOracleQuery $017E75D0 End (1 record processed)
Duration = 1.422
2006-3-25 17:00:17 TOracleQuery $017E75D0 Start Query.Next for up to 1 record
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0
Duration = 0.01
Duration = 0.03
Duration = 0
Duration = 0.01
2006-3-25 17:00:17 TOracleQuery $017E75D0 End (0 records processed)
Duration = 0
2006-3-25 17:00:17 TOracleQuery $017E75D0 Start Query.Execute
SQL = select column_name
from sys.all_part_key_columns
and name = :object_name
and trim(object_type) = 'TABLE'
order by column_position
2006-3-25 17:00:17 TOracleQuery $017E75D0 End (2 records processed)
Duration = 0.01
SQL = select partitioning_type
from sys.all_part_tables
Duration = 0.01
SQL = select * from sys.all_queue_tables
where queue_table = :object_name
Duration = 0.01
2006-3-25 17:00:17 SQLForm stat_month, varchar2(8), optional
2006-3-25 17:00:17 SQLForm 32 rows selected in 0.331 seconds (more...)
2006-3-25 17:00:23 TOracleQuery $017E75D0 Start Query.Execute
SQL = select 'x' from dual
2006-3-25 17:00:23 TOracleQuery $017E75D0 End (1 record processed)
Duration = 0.01
2006-3-25 17:00:23 TOracleQuery Query Start Query.Execute
:ID = Null
2006-3-25 17:00:23 TOracleQuery Query End
Duration = 0
2006-3-25 17:00:23 MainForm Closing
2006-3-25 17:00:23 ChangeUserPref , PlanViewType
2006-3-25 17:00:23 ChangeUserPref end
2006-3-25 17:00:23 ChangeUserPref Logon, Username
2006-3-25 17:00:23 ChangeUserPref Logon, Database
2006-3-25 17:00:23 ChangeUserPref Logon, ConnectAs
2006-3-25 17:00:23 ChangeUserPref , LastNewsRead
2006-3-25 17:00:23 ChangeUserPref , LastNewsItem
2006-3-25 17:00:23 ChangeUserPref , LastUpdateItem
2006-3-25 17:00:23 TOracleSession PLSQLDevForm.Session Start Session.LogOff
2006-3-25 17:00:23 TOracleSession PLSQLDevForm.Session End
Duration = 0
2006-3-25 17:00:23 MainForm Closed
2006-3-25 17:00:23 Destroying TSQLForm
2006-3-25 17:00:23 TOracleSession $021BE410 Start Session.LogOff
2006-3-25 17:00:23 TOracleSession $021BE410 End
Duration = 0.01
2006-3-25 17:00:23 TSQLThread SQLThread Suspend ended
2006-3-25 17:00:23 Destroyed TSQLForm
2006-3-25 17:00:23 ChangeUserPref LogonHistory,
2006-3-25 17:00:23 ChangeUserPref DSA,
2006-3-25 17:00:23 ChangeUserPref ColumnAssociations,
2006-3-25 17:00:23 ChangeUserPref ImportAssociations,
2006-3-25 17:00:23 ChangeUserPref BrowserFilters,
2006-3-25 17:00:23 ChangeUserPref BrowserFolders,
2006-3-25 17:00:23 ChangeUserPref SessionQueries,
2006-3-25 17:00:23 ChangeUserPref ExternalTools,
2006-3-25 17:00:23 ChangeUserPref Documents,
2006-3-25 17:00:23 ChangeUserPref Reports,
2006-3-25 17:00:23 MainForm Destroying
2006-3-25 17:00:23 MainForm Destroyed
2006-3-25 17:00:23 Finalization HTMLUnit
2006-3-25 17:00:23 Finalization HTMLUnit done
2006-3-25 17:00:23 Finalization PLSCommon
2006-3-25 17:00:23 Finalization PLSCommon done
2006-3-25 17:00:23 Finalization DBObjectUnit
2006-3-25 17:00:23 Finalization DBObjectUnit done
2006-3-25 17:00:23 Finalization RepUnit
2006-3-25 17:00:23 Finalization RepUnit done
2006-3-25 17:00:23 Finalization ReportCommon
2006-3-25 17:00:23 Finalization ReportCommon done
2006-3-25 17:00:23 Finalization PlanUnit
2006-3-25 17:00:23 Finalization PlanUnit done
2006-3-25 17:00:23 Finalization MacroUnit
2006-3-25 17:00:23 Finalization MacroUnit done
2006-3-25 17:00:23 Finalization StatUnit
2006-3-25 17:00:23 Finalization StatUnit done
2006-3-25 17:00:23 Finalization DBNamesUnit
2006-3-25 17:00:23 Finalization DBNamesUnit done
2006-3-25 17:00:23 Finalization TotalRecallUnit
2006-3-25 17:00:23 Finalization TotalRecallUnit done
2006-3-25 17:00:23 Finalization RowExportUnit
2006-3-25 17:00:23 Finalization RowExportUnit done
