Gerald Clayburn
I am having a problem with errors while accessing the help file for PL/SQL Developer. Everytime I go to a page of help I get the following popup box: An ActiveX control on this page might be unsafe to interact with other parts of the page. Do you want to allow this interaction. When you click yes it then throws a scripting error that indicates that the object doesn support this property or method. Any ideas what might be causing this? It doesn't happen with other help files from other companies.
