grouping with CUBE on DUAL doesn't work
Ivan C.
Greetings!
I guess you have some sort of "local" implementation for queries against the DUAL table, because I'm getting different result than in SQL*Plus.
PL/SQL Developer:
SQL> select 1 from dual;
         1
         1
SQL> select 1 from dual group by cube (1);
         1
         1
         1
SQL> select 1 from dual group by cube (1, 2);
         1
         1
         1
         1
         1
SQL*Plus:
         1
         1
         1
         1
         1
         1
Could you please fix it?
Thank you beforehand.
Ivan C.
There is no local implementation. The query is sent to the server, and the results are displayed. I guess that SQL*PLus does something with this result set, because if you run the following query it clearly says "4" (both in SQL*Plus and PL/SQL Developer):
SQL> select count(*) from
  2    (select 1 from dual group by cube (1, 2));
  COUNT(*)
         4
SQL>
