"Go to Declaration" on Ctrl+Click does not work on duplicate functions with different arguments
Sirius
Just create a new package and add this code:
Function Fn(a number, b number) return number is
    return a + b;
  Function Fn(a number) return number is
    return Fn(a, 1);
  Procedure Test is
    v number;
    v := Fn(1);
Then try this:
1. Ctrl+Click on Fn inside Test. Cursor goes to the 1st function. But it should go to the 2nd. Because it is calling Fn with 1 argument.
2. Ctrl+Click on Fn inside 2nd Fn. Cursor goes to the 2nd function. But it should go to the 1st. You know why:)
That's annoying!
