Function View -PLSQL Developer
Kishu
To view function source code[Dev Database], i can able to right click and view and Edit options are available, But when Database is only readonly[Production], we can't even view the Function Source code by right clicking, is there any other ways?
Think you'll need to speak to your DBA's. Most production environments dont allow code to be seen. You might be able to see the specs but not the actual code.
No, Actually they have given access to read and we can see the same in SQL Developer and TOAD but why not in PL/SQL Developer?, but i can see from dba_source table. And also i tried enabling the option "Use DBA Views if available" under Oracle => Options. but this also no use.
I didn't get what BUG you're referring, i have select privilege on mentioned tables(DBA_VIEWS) but still i'm not able to view that,but i can view from DBA_SOURCE table
