Find & Replace dialog not described in manual
Then the search is not limited to comments, strings or other code sections. It is the same as all 3 options are checked.
Does this mean, that text is always parsed when using Find & Replace?
Is there a way to make a 'raw' search and replace, i.e. treat the file as a plain text file?
If all "search in" items are checked or no "search in" item is checked all text will be searched as if it were plain text.
