Filter SQL inconsistent with Local SQL
Question: Why is the SQL allowed in TOracleDataSet.Filter not consistent with Borland's Local SQL?
Two differences (off the top of my head) are:
1) not allowing the "like" predicate but instead allowing "field = value*"--this is nice but it would also be nice to be able to use standard SQL;
2) requiring parentheses around clauses when there are two or more, even if not needed to parse out the logic (e.g., "where field1 = value1 and field2 = value2")--standard SQL doesn't have this requirement.
I'm certainly able to work around these two examples, but it's nevertheless frustrating to *have* to work around them.
Steve
Filter conditions are not SQL. If you prefer SQL conditions, you can of course use the SQL property instead.
Well, of course they are. A limited SQL, but SQL nonetheless. Now, how about an answer to my question?
Steve
If you check the Borland documentation, you will see that the Filter is simply not SQL. It does not specify a like operation, and uses the asterisk as wildcard character. It uses the following example:
State = 'M*'
