Field Comment to Text Editor Doesn't Work
zakko
In PLSQL Developer 13 and 14 it's not possible to view a comment of a selected row from description table in the text editor. If you click on the three-dots-icon on the right in description table nothing happens.
This only applies to the selected row (blue background). All other rows work.
Is there a reason for this or is it somehow switchable?
Same behaviour when viewing or editing a record in Single Record View.
Can't open popup editor for Varchar2 or Clob fields.
Multiple Record View works okay.
Using version 14.
Thanks !
