Feature request, SQL Window: add "Select row" and "Select column" to right click menu
Claus Pedersen
When right-clicking in the data grid in the SQL Window there is an option "Select all". Could the options "Select row" and "Select column" be added (and of course the underlying functionality :D )
P.S. when cursor is in the grid and right clicking, the menu options "Copy" and "Copy with header" are available, but nothing is copied. They should be disabled when nothing is marked.
On the other hand "Copy to Excel" always copies everything in the grid, even if no or one field are marked. I would expect that the marked fields only are copied. Could you consider making the menu text a little more specific, like: "Copy field to Excel", "Copy row to Excel", "Copy column to Excel", "Copy all to Excel"?
