Feature request for PL/SQL Beautifier
stevec
Could handling SQL script be added to the list of enhancements for the Beautifier please
- I appreciate you can select the PL/SQL in the SQL script, but it's a bit of a pain
Do you mean a SQL script in the Command Window, with multiple SQL statements, PL/SQL Blocks, and SQL*Plus commands?
Yeap Marco, I've got mixed SQL, SQL*Plus + PL/SQL scripts
- if I try the Beautifier and there are none-PL/SQL lines at the beginning of the script, I get the warning "PL/SQL Beautifier could not parse text"
- however it works if there are none-PL/SQL lines at the end of the script ??
Another point, on WHERE clauses with AND's in, is there any way to format the AND's ??
e.g. current output
WHERE dpcase.caseno = dphrqcmp.caseno AND dpcase.dpclass3 = 'NEW' AND
dpcase.dpclass4 = 'GREEN';
would like
AND dpcase.dpclass4 = 'GREEN';
or even
Blast the html stripped out the leading spaces on the second example
so . are
...AND dpcase.dpclass3 = 'NEW'
...AND dpcase.dpclass4 = 'GREEN';
I have added your first request to the list of enhancement requests.
Additional formatting control for conditions is on our to-do list.
I was gonna ask for the "AND on new line" stuff. Si I will ask for 3 nice to have (personal) points
"first parameter on new line":
P_Procedure (
Pi_First_parameter T_type ,
Pi_Second_parameter T_type )
as
V_Variable ...
"space before/after symbol":
x:=(a+b)/c*100| |'%';
would then become:
x := ( a + b ) / c * 100 | | '%' ;
"Align = signs"
select *
from a_table
where fisrt_fld = P1
and second_fld = p2;
damn, UBB is not the best sql editor I know :P
Use:
(your formatted code here)
[/ code] (no space between / and code)
