FAQ: Slow performance when logging on or executing a SQL Window or Test Window
faq
A logon in PL/SQL Developer takes a very long time. When I subsequently execute a SQL Window or Text Window, this also causes a huge delay.
This seems like a connection problem. Each SQL Window and Test Window uses its own session, and therefore needs to connect when executed for the first time. You should check this file:
%OracleHome%\Network\Admin\sqlnet.ora
If it contains this line:
SQLNET.AUTHENTICATION_SERVICES=(NTS)
Change it to a comment line:
# SQLNET.AUTHENTICATION_SERVICES=(NTS)
This is a known Oracle Installer bug that can cause unacceptable connection delays.
