Export with Method="SQL Inserts" does not read 'Drop' parameter
When I run the following command in a Command Window the export does not process the 'Drop' parameter:
Export Tables=TABLENAME Method="SQL Inserts" Drop DisableTriggers DisableFKs Commit="500" Filename="c:\temp\tablename.tab" Wait
See screenshot.
This also happens with the Create parameter
I am using PL/SQL Developer 15.0.2.2054
