Explain Plan Preferences
BJCooperIT
Scenario:
1. There is an Explain Plan window open and I click the Preferences icon.
2. I then add, delete or move a column within my preferences.
3. Then I click the "Apply" button.
4. Now I click the "OK" button.
When I return to the open Explain Plan window the changes have not been made to the window. Sometimes after making a preference change the columns can not longer be widened/narrowed by dragging the headings.
The changed column selection will only be applied after rerunning the Plan Window, but other than that I don't see any problem.
Do you know the exact steps to reproduce this?
The steps are pretty much as I described. If the changes only take place after "rerunning the Plan Window", then what is the difference between the "Apply" button and the "OK" button? Both accept your changes which only appear when you run another Explain Plan.
