explain plan not working
Roger25
I want to display the explain plan for a given select statement in Command Window. I tried:
Connected to Oracle Database 11g Enterprise Edition Release 11.2.0.3.0
Connected as system@orcl
SQL> explain plan for select * from hr.employees;
Explained
SQL>
so.. where is the plan?
Also I tried with:
SQL> select * from hr.employees;
and then
SQL> select * from table (dbms_xplan.display_cursor);
But I got:
PLAN_TABLE_OUTPUT
SQL_ID 9m7787camwh4m, child number 0
begin :id := sys.dbms_transaction.local_transaction_id; end;
NOTE: cannot fetch plan for SQL_ID: 9m7787camwh4m, CHILD_NUMBER: 0
Please verify value of SQL_ID and CHILD_NUMBER;
It could also be that the plan is no longer in cursor cache (check v$sql_p
8 rows selected
I want to display the explain plans in Command window because it's well formatted and I can copy/paste them into OTN forums, for example.
My version of software is 10.0.4.1708.
Thank you.
It is not possible in PLD 'as is'
but
I made the following workaround:
1. Run SQL with unique comment
select /*mycomm*/ * from dual
2. Run XPLAN
select * from table(dbms_xplan.display_cursor(sql_id =>
          (select sql_id from v$sql
                  where upper(sql_text) like '%/*MYCOMM*/%' and upper(sql_text) not like '%/*MYCOMM1*/%'),
          format => 'ADVANCED')
This works for me:
SQL> explain plan for select * from dual;
Explained
SQL> select * from TABLE(DBMS_XPLAN.DISPLAY());
PLAN_TABLE_OUTPUT
Plan hash value: 272002086
| Id  | Operation         | Name | Rows  | Bytes | Cost (%CPU)| Time     |
|   0 | SELECT STATEMENT  |      |     1 |     2 |     2   (0)| 00:00:01 |
|   1 |  TABLE ACCESS FULL| DUAL |     1 |     2 |     2   (0)| 00:00:01 |
8 rows selected
Nice :) ok
and can we control which columns from explain plan should be displayed in this command window? In a SQL Window, we can press the Settings button and add what information we want.. but in the explain plan above, how can control which information to appear?
One more thing, to the developer: it would great if we would have a parameter, which we set to ON, and after issuing a query, the query plan is automatically displayed (without we issuing "select * from table (......."
And also, why AUTOTRACE cannot be set in PL/SQL Developer, like in the following example (SQL*Plus):
SQL> set autotrace on
SQL> select * from dual;
D
X
Execution Plan
Statistics
5 recursive calls
0 db block gets
5 consistent gets
3 physical reads
0 redo size
331 bytes sent via SQL*Net to client
337 bytes received via SQL*Net from client
2 SQL*Net roundtrips to/from client
0 sorts (memory)
0 sorts (disk)
1 rows processed
SQL> set autotrace off
In PL/SQL Developer we get "Cannot set AUTOTRACE"
Thanks.
There's a documentation for the dbms_xplan package
Thank you.
IF you can implement this :
in future versions, it would be great.
Regards,
my 2 cents as i'm passing by.
We had bad surprises with plan_table synonym in 11g/12c SPM. In some cases baselines were not shown in the notes, causing many headscratches.
here is the queries template I use now:
explain plan into sys.plan_table$ for
SELECT * FROM DUAL;
select *
from table(dbms_xplan.display(table_name => 'sys.plan_table$', format => 'ADVANCED +peeked_binds ALLSTATS LAST' ));
note: generally i remove the "allstats last" format, and if you don't want to many stuff, replace "ADVANCED" by "ALL".
hope this help
In my PL/SQL Developer, the plan appears as :
SQL> select * from table(dbms_xplan.display());
PLAN_TABLE_OUTPUT
|   0 | SELECT STATEMENT                        |                        |    18
|   1 |  SORT ORDER BY                          |                        |    18
|   2 |   NESTED LOOPS OUTER                    |                        |    18
|   3 |    NESTED LOOPS OUTER                   |                        |  4451
|   4 |     NESTED LOOPS OUTER                  |                        |   544
|   5 |      NESTED LOOPS OUTER                 |                        |    66
|   6 |       NESTED LOOPS                      |                        |  8168
|   7 |        FAST DUAL                        |                        |     1
|   8 |        COLLECTION ITERATOR PICKLER FETCH| XMLSEQUENCEFROMXMLTYPE |  8168
|   9 |       VIEW                              |                        |  8168
|  10 |        COLLECTION ITERATOR PICKLER FETCH| XMLSEQUENCEFROMXMLTYPE |  8168
|  11 |      VIEW                               |                        |  8168
|  12 |       COLLECTION ITERATOR PICKLER FETCH | XMLSEQUENCEFROMXMLTYPE |  8168
|  13 |     VIEW                                |                        |  8168
|  14 |      COLLECTION ITERATOR PICKLER FETCH  | XMLSEQUENCEFROMXMLTYPE |  8168
|  15 |    VIEW                                 |                        |  8168
PLAN_TABLE_OUTPUT
|  16 |     COLLECTION ITERATOR PICKLER FETCH   | XMLSEQUENCEFROMXMLTYPE |  8168
Why I cannot see all the columns you see? (e.g. CPU Cost)
