Explain plan extentions in 9i ?
Are you planing to implement the new explain plan extentions in 9i in PL/SQL Developer ?
Like Predicates, Temp space and etc.
Predicates been the most important.
explain plan for
set linesize 130
select * from table (dbms_xplan.display);
Temp space is already supported. Predicates will definitely be added shortly.
I would like to ask for a feature.
I'd like to see the results of the dbms_xplan.display function in the explain plan window.
You could place the currently used table and the dbms_xplan output in a tabbed pane, so I could decide which one I'd like to see.
Sorry for my BAD english.
Feri
