Hello !
I am searching for a simplification and want to make a suggestion. (If it's already implemented and I haven't found it, pls give me a hint...)
I very often have the situation that after coding of a procedure I want to test it with a defined environment of table data. Therefore I always open a command window and call a SQL-Script by typing
@d:\projects .. bla bla ...\xyz.sql
Do you think its possible to provide a mechanism that allows a user to insert buttons, that call a SQL Script when pressed. Path and Scriptname has to be configured in the preferences.
Posssible ?
Bye from Hamburg,
Andree
Posssible ?
Bye from Hamburg,
Andree
