Execute only current sql without selected ?
bertrand
Hello
In a sql windows , i have 2 sql orders and i just want to execute the order where the cursor is . It's possible without selected text ? ( juste execute the order who my cursor is ... )
---> I have found the solution : Auto select instruction in options --> It's OK
Or use the ExecuteCurrentStatement plugin. Download it from bar-solutions.com [check software [-] Plug-ins]
Kindest regards,
Patrick
