ExamDiff Pro supports syntax highlighting but if i compare opened object with database source then the Developer creates two files without extension (Editor and Database files in TEMP).
ExamDiff Pro can not be configured to use sql syntax if none of the file has a file extension.
Could it be possible to add a .suffix for these files?
And the second question. If I modify and save the Editor file in the ExamDiff, I have to take the entire code into the clipboard and paste it manually into the developer, or can the Developer load the saved changes?
