Error while trying to retrieve text for error ORA-12222
dbawork
I can connect to a Oracle 7.2 database using SQL_Plus 3.2 but thru PL/SQL Developer I get
"Error while trying to retrieve text for error ORA-12222". I have checked the TNSNames.ORA and it has the correct descriptor address.
This problem came after I reinstalled Oracle 7.2 last week. Yeah, 7.2 is still alive at my work.
Would appreciate any help. Thanks!
Since the text for this error cannot be retrieved, it would seem that there is something wrong with the installation of the Oracle Home that PL/SQL Developer is using.
Can you start PL/SQL Developer without connecting, go to Help > About, press the 'Info' button, press the 'Copy all pages' button on this info screen, and paste this text into an e-mail reply?
Here is the what I got from Help>About...
Thanks for the help though.
--- Info ---
PL/SQL Developer
Version 5.1.4.728 (MBCS)
13.16288 - 5 user license
Windows XP version 6.0 (build 2600) Service Pack 1
Physical memory : 523,568 kB (48,676 available)
Paging file : 887,356 kB (510,344 available)
Virtual memory : 2,097,024 kB (2,051,260 available)
Parameters
C:\Program Files\PLSQL Developer\PLSQLDev.exe
Preferences
Session mode: Multi
OCI Library:
Use OCI7: True
Plug-Ins
Aliases
Homes
DLLs
C:\ORANT\bin\oci.dll
C:\ORANT\bin\ORA72.DLL
C:\ORANT\bin\ORA803.DLL
C:\ORANT\bin\ORA804.DLL
C:\ORANT\bin\ORA805.DLL
C:\ORANT\bin\ORANT71.DLL
TNS File
C:\ORANT\Net80\Admin\tnsnames.ora
Using
Home: T:MENBS:BSS
DLL: C:\ORANT\bin\oci.dll
OCI: Version 7.3
--- Registry ---
SOFTWARE\ORACLE
ORACLE_HOME = C:\ORANT
API = C:\ORANT\DBS
NLS_LANG = AMERICAN_AMERICA.WE8ISO8859P1
ORACLE_GROUP_NAME = Oracle for Windows NT
RDBMS72 = C:\ORANT\RDBMS72
MSHELP_TOOLS = C:\ORANT\MSHELP
VS10 = C:\ORANT\BIN
RDBMS72_CONTROL = C:\ORANT\DATABASE
RDBMS72_ARCHIVE = C:\ORANT\DATABASE\ARCHIVE
ORACLE_SID = BSS
PLSQL22 = C:\ORANT\PLSQL22
PRO17 = C:\ORANT\PRO17
NLSRTL31 = C:\ORANT\NLSRTL31
ORA_NLS = C:\ORANT\NLSRTL31\DATA
ORA_ORCL_PWFILE = C:\ORANT\DATABASE\PWDORCL.ORA
SQLPATH = C:\ORANT\DBS
PLUS32 = C:\ORANT\PLUS32
EXECUTE_SQL = PLUS32
PRO21 = C:\ORANT\PRO21
SOFTWARE\ORACLE\SECURITY
ORA_ORCL_STARTMODE = TRUE
--- Path ---
C:\ORANT\bin
C:\WINDOWS\system32
C:\WINDOWS
C:\WINDOWS\System32\Wbem
C:\Program Files\Microsoft SQL Server\80\Tools\BINN
C:\ORAWIN\BIN
--- TNS names ---
Marco,
The script above tells me that the pathname to the TNSNames.ora is incorrect. It should be C:\orant\NETWORK\ADMIN\TNSNames.ora instead.
How do I set it right?
Can you go to Tools > Preferences > Options tab page, select ora72.dll from the OCI Library list, restart PL/SQL Developer, and try again?
This may fix both problems (error message + tnsnnames.ora).
Marco,
That fixed it. This is a big relief. In fact, I did not even have to restart it. But I will anyways.
Thanks a ton for the help.
