(Delphi2006, Oracle9i)
consider the folowing SQL:
SELECT *
FROM V$SQL_PLAN B
WHERE B.ADDRESS=HEXTORAW
addr)
AND B.HASH_VALUE=TO_NUMBER
hashv)
DeclareAndSet('addr', otString, sqladdr ); // works ok
DeclareAndSet('hashv', otString, hashval ); // causing problems
//sqladdr = string contains HEX string
//hashval = string, contains actual HASH_VALUE(on oracle type=NUMBER)
When executed the following error is returned:
ORA-01460 unimplemented or unreasonable conversion requested
I have to pass HASH_VALUE as string because of overflow conversion problems as this value can be quite large number.
Any hints?
Thank you for your time.
Dan.
SELECT *
FROM V$SQL_PLAN B
Any hints?
Dan.
