Error Opening Document
In PL/SQL Developer, when I try to "Copy to Excel" the Result Dataset, then I get the above said error.
It tries to open Microsoft Excel to export the result set, after trying for a minute it throws this error.
If anyone has any clue on why this is happening, your help will he highly appreciated.
I'm on Windows XP (SP3) with Excel 2003 and this 'Copy to Excel' function works flawlessly for me.
Might be interesting to know what version(s) you are working with.
I have three guesses.
1. Do you have more than 64 thousand rows? I think Excel 2003 has a limit of that.
2. Is the SQL really large? PL/SQL Developer puts the SQL statement into one cell on the second tab and there is a limit to how big it can be. I thought it gets truncated, but it might be something to look at.
3. Perhaps one of the cell's data is throwing it off somehow. Can you open it if there is only 1 row? If so, you might be able to find the row that is causing the problem and report it. For example, see if the first half works. If so, check the second half. Keep dividing it until you have the row.
--- I get this error even if the number of rows is as less as 10, It has something to do with the pl/sql developer not able to open the excel document.
-- I had tried "select * from tab;" I think this is a very small sql. I am guessing it has something to do with the compatibility between pl/sql developer and excel.
-- whenever I get this error, everytime I try doing it second time, and then it works perfect, If the reason could have been what you stated above, the problem would occur each and everytime. My problem is intermittent.
Sorry if this wasn't clear the first time. I meant the version of MS Office and Windows. Seems to me that your problem is situated there rather than in PL/SQL Developer.
