enhancement request: Test Window for pipelined function
marek
it would by nice if plsqldev could create Test Window for pipelined function, i.e. not
declare
-- Non-scalar parameters require additional processing
result ma.map_xutils3.line_tbl_type;
-- Call the function
result := ma.map_xutils3.clob2lines(p_clob => :p_clob,
p_delim1 => :p_delim1,
p_delim2 => :p_delim2,
p_str => :p_str,
p_blob => :p_blob,
p_csid => :p_csid,
p_utf8 => :p_utf8);
but
select * from table (ma.map_xutils3.clob2lines(p_clob => :p_clob,
p_str => :p_str,
p_blob => :p_blob,
p_csid => :p_csid,
p_utf8 => :p_utf8))
Or you can use the cursor type variable of the test window.
So e.g., open :result_set for select * from table (ma.map_xutils3.clob2lines(p_clob => :p_clob,
p_str => :p_str,
p_blob => :p_blob,
p_csid => :p_csid,
p_utf8 => :p_utf8)):
Where :result_set is of "type" "cursor" in the test window. Then after running the script you van press the ellipsis (..) all the way to the right of the "value" column in the test window to see the results.
