ScottMattes
PLSD 10
Today I need to hand jam some test data, so I queried the table, selected the first result row and exported as SQL. The resulting INSERT statement is a great starting point.
I would like to be able to have inline comments put on each value line - the comment would be the column name. This would be awesome for most of our tables because the column lists are long.
Here is an example of what I am after:
I know that it is optional, but I'd also like generated INSERTs to have FIELDS in them.
Thank you.
	INSERT INTO myTable
FIELDS
(Col_1,
 Col_2)
VALUES
('xyz',  -- Col_1
 123     -- Col 2);I know that it is optional, but I'd also like generated INSERTs to have FIELDS in them.
Thank you.
