Frank Kintrup
we have sometimes rather cryptic database and connection names like "HZ3DBU.AS-HZ3-DEV-01" and it is often kind of hard to remember which database instance was on which system and so on. However, internally most of this instances have "nicknames" like DEV01 or "PRODUKTION", which are quite easy to remember.
Could you add an edit field to the login dialog to "name" an instance and optionally display that name alongside the proper instance info when it is selected from a list or displayed somewhere? That would be very very helpful!
Frank
Frank
