Enhancement request for spec/body edit
vc
IF you edit the spec and body of a package or type, and only change the body, why does to spec get re-compiled? This is mildly annoying with packages, but with object types (with dependents), you either have to open a new window to edit just the body, or open a command window and drop the type before clicking on the execute (gear) button.
I need a way to either execute only the body tab, or close the spec tab without closing the body.
Any way to have the spec default to read-only? I.E. View Spec/Edit body option?
