Full details to justify this request can be found here:
Detailed proof of concept for improving PLSQL Developer connect time
More recent versions of Oracle database take an extraordinary amount of time just to select zero rows from dba_ views. Many of us need to use the option "Use DBA Views if available" to see all objects in the PL/SQL Developer object browser. However, with the default session options, it can take over a minute for PL/SQL Developer to complete its connection step because of the slowness of the dba_ views.
This request is to allow for a .sql file to be executed on what ultimately becomes the Primary Connection for PL/SQL Developer prior to any of the "select * from sys.dba_xxxxxx where rownum < 1" queries. The idea is that by executing the requested .sql file, we can set whatever session parameters aid response time of the dba_ views in our database environments.
Thanks for your consideration. I really hope you will choose to implement this soon as it would save a bunch of us a whole lot of time!
