Enhancement: columns and parameter prefix
Roeland
Is it possible to change te default prefix for parameters and columns. Now the default is "v_" but at our company the standard is "p_".
It is really a small question, but it would help a lot.
Would be nice to make a preference for this. We use lv_ (Local Variable) and pi_ (Parameter In).
Or better yet, let's agree on a global standard naming convention. On second thought, that might not work. As Andrew S. Tanenbaum said: "The nice thing about standards is that there are so many of them to choose from."
regards,
Patrick
How do I turn this feature on? Or is it still not implemented? In that case, could you move it higher on the list again plz?
Thank you
I am also looking for this as well. What is the status? What I am looking for is when I drag a table to a blank window and select "Update" or something from the quick menu I want the variables to be 'p_xxxxxxxxx' instead of 'v_xxxxxxxx'.
